Found water in the cab....
My bet is with the battery box first. Even if the bottom of the box is intact, if the drain hole is clogged a downpour can fill the box and water can go 'up' the frame and end up in the pass. footwell.
You can use a piece of weedeater line to clean out your sunroof and rear hatch drain tubes. I usually keep one in my detailing/wash kit. A long zip tie is great for the rear hatch slits.
Sit a large sponge in the pass. footwell until you figure out the problem if more rain is expected.
Yes, BEHIND the passengers seat can be the battery box....trust me i really know this one.
If is was an early I would be positive but.....
On the drivers side I have seen stress crack the firewall near the drain. If it cracks on the drain side I could see water intruding was it ran off. (if it IS cracked you will be able to see it looking under the dash with the hood open...."hey, is that sky and trees I see?")
Water in the drivers footwell usually comes from the under-hood compartment where the wiper motor is filling up with water. When full, the water spills over into the AC/heat ducting and drips down onto the carpet. Check the drains in the underhood compartments by the wiper motor and the battery. Mine were clogged and the drivers side floor mat was soaking wet.
A couple leaks I found on my car you may want to check:
1) gas cap drain hole grommet...this can leak down into the rear cubby holes and possibly make it's way to the rear pass. floor.
2) On the 85.5 and later cars, there is a wire harness that passes thru the cowl near the fuse box. Mine was torn and would drip water down on my feet or carpet.
Originally Posted by Lonely Raven
Yeah, but my puddle is BEHIND the passenger seat, not in front.
I'm going to shop vac it when I get home from work tonight, assuming it's
not a block of ice by then...
And the thread circles back again
http://forums.pelicanparts.com/showt...ighlight=por15
Here is the Por-15 writeup if anyone is interested. The stuff really kicks. I am going in next year and doing the whole windscreen to firewall area.
