best car cover to buy...
What kinds do you use, I need to put one on the 944 for the winter ![Frown](https://rennlist.com/forums/images/smilies/frown.gif)
it has to live outside, because the parents need the garage...
and I'm stuck driving the reliant, well unless I buy this '83 volvo 245 turbo station wagon i've been looking at haha
Macfreak007,
I have an indoor/limited outdoor use cover from California Car Cover Co. It is the best car cover I have seen. Its definatly not the cheapest cover you can buy, but The workmanship is excelent. The website for California Car Cover Co. is: www.calcarcover.com
If I remember right, mine is the Noah brand one. It sounds like you would want one made for just outdoor with good UV protection and better protection against rain and such.
Give them a call, and let them know what you will be using the cover for, and they will tell you what the best cover would be for what you need it for. There are other companies out there that I found, but I ended up going with Cal Car Cover becuase of their excelent customer service, not to mention an awesome cover.
Hope that helps,
Matthew
Hope that helps,
Matthew
Carl, while in Louisville I used a Covercraft Technalon outside on my 944S2 cab. The cover material is quite thick and really protects the car. In fact, I bought a second cover and use it indoors now on the 951.
Only problem I found is when it rains, since it does soak up a lot of water. Freezing rain would be even worse, but there's not much you can do about that when cars are outside.
IIRC, there's another Covercraft line which sheds water more easily than the Technalon, but costs a bit more. Whatever you do, you don't want a totally water resistant cover (e.g. plastic) because it will allow moisture to build up underneath, which is not good for auto electronics, rust, etc.
