DME & KLR pin-out diagram
Old 12-24-2004, 01:12 PM
Dark Lightning
Dark Lightning's Avatar
Default DME & KLR pin-out diagram
Has anyone taken the time to generate a complete text based pin-out diagram for a 951 DME & KLR? Yes yes I can check in the FSM but I'm looking for a list:
Connector 1, Pin 1, Coolant Sensor
Connector 1, Pin 2, Fuel Injector #1
etc.
Acceptable replies include "Yes", "No", and "Here's a link to one." No need to ***** a simple thread, Porsche-O-Phile.
Old 12-24-2004, 01:55 PM
Porsche-O-Phile
Porsche-O-Phile's Avatar
OK, "no".
You asked for that one.
Seriously though, I believe I may have one - I'll look.
Old 12-24-2004, 02:03 PM
theedge
theedge's Avatar
Here ya go.
Old 12-24-2004, 02:05 PM
Dark Lightning
theedge - PERFECT. That's exactly what I was looking for, thanks.
Is that in the FMS or published elsewhere?
Old 12-24-2004, 02:13 PM
theedge
theedge's Avatar
I THINK it was in a separete electrical diagram book, but I dont know. Someone posted those in a thread a long time ago and I saved them, knowing id need them.
Old 12-24-2004, 03:40 PM
Dark Lightning
Just in a different form:
Code:
DME
01 - Ignition pulses on ign. coil - 1
02 - Throttle switch, Idle contact - 2
03 - Full load signal from KLR
04 - Start signal (ign. lock - 50)
05 - Ground and shielding from reference mark sensor
06 - Air flow sensor - 4 (NTC I)
07 - Air flow sensor - 2 (sensor plate potentiometer)
08 - Speed sensor
09 - Air flow sensor - 3
10 - Perf. data change (to -1 for CH, S, AUS, NZL, Cal., Japan)
11 - Conn. point 4-pin term 1 (economy control)
12 - Test socket (A) (USA / unleaded gasoline engines)
13 - NTC II
14 - ti-signals, injectors 3+4
15 - ti-signals, injectors 1+2
16 - Ground
17 - Ground
18 - Power supply relay G 5 - 87
19 - Ground
20 - Ground activation relay G 5 - 85b
21 - Conn. point 4-pin term 2 (tachometer - 1)
22 - Air flow sensor - 1 (NTC I)
23 - Shielding (speed sensor / oxygen sensor)
24 - Oxygen sensor (USA / unleaded gasoline engines)
25 - Reference mark sensor
26 - Reference mark sensor
27 - Speed sensor
28 - Ground
29 - A/C compressor (+)
30 - Altitude correction unit (USA / unleaded gasoline engines)
31 - Trigger signal for KR
32 - TD* input final stage from KR
33 - Idle positioner - 3
34 - Idle positioner - 5
35 - Power supply relay G 5 - 87
KLR
01 - Diagnosis
02 - Timing valve (output)
03 - LED
04 -
05 - Intake vacuum signal (output for pressure display)
06 - U (sheet)
07 -
08 -
09 - Ignition signal (input)
10 - Ground
11 - Ground
12 - Ground, shield knock sensor
13 - Knock sensor
14 - Car ground final stage timing valve.
15 - Knocking yes/no (output)
16 - Ignition signal (output)
17 -
18 - Full load signal (output)
19 -
20 - Car ground (electronic ground connection)
21 - Throttle valve position: Angle sensor - supply
22 - Throttle valve position: Angle sensor - tap
23 - Throttle valve position: Angle sensor - ground, shield for angle sensor wire
24 - tr-signal (input)
25 -
Old 12-24-2004, 03:48 PM
Danno
Danno's Avatar
It's also best to match up to the wiring schematic as well because some of those labels from the pin-out sheet is ambiguous. For example the speed & ref sensors are listed twice with the same name, but there's actually a signal+ and signal- orientation.
Old 12-24-2004, 09:57 PM
Mr. Avionics
Mr. Avionics's Avatar
Thats nice, now how about one for the early N/A's.
Thanks in advance,
Bill
Quick Reply: DME & KLR pin-out diagram
