Running hot.. what could this be?
UAE Rennlist Ambassador
Originally Posted by schlag
Yeah it does actually jump around a bit, but I thought that was perhaps due to air working it's way out of the system. I also noticed that (oddly) if I press the brake pedal, the temp guage fluctuates slightly. Perhaps it is the guage?
With the exception of the voltage regulator in the alternator and some "onboard" regulators in the DME, there is no external voltage regulation.
Turning something on and off (like the brake lights, turn signals or emergency flashers) causes brief changes in voltage throughout the electrical system.
Because the gages and sensors are referenced to ground potential (0 volts), a decrease in the applied voltage causes the gage to indicate "higher."
To get a more "stable" monitoring system would require regulated voltages below 12 volts for both sensors and gages. This is one reason Porsche went from using unregulated 8 volts to regulated 5 volts for the AFM reference in the '85.5 and later models.
In the early cars an unregulated 8 volt reference to the AFM is supplied by the DME via a resistive voltage divider. Because this reference is not regulated, changes in system voltage cause chages to the AFM reference.
By lowering the reference to 5 volts and using a voltage regulator, the reference to the AFM does not change with changes in system voltage.
