At what oil psi will?
Nerd Herder
Pete, I talked to Paul last night, He has a the full 6 quarts in. he drained and refilled to make sure he was seeing things right. Wow, you can catch oil??-
FWIW, after a spirited hiway run and well at normal operating temp, 5w30 Mobil 1 will be at 2 bar. 0W30 will be just below 2 regardless of ambient temp. (unless very cold, like 30 F or colder)
I notice a higher oil pressure reading in the winter until properly warmed up on the same viscosity oil.
(At 4 degrees my 5w30 Mobil1 oil is probably like caramel out there today. )
Is it around 5 on the gauge at startup? It should still idle around 2-3 when fully warmed up.
If there is a problem I would look at the oil pressure sender and the OPRV first.
OK, cold start idle psi is 4-4.3 bars easily goes to 5 with more rpm.
I guess I wasn't clear earlier. I had 6 1/2 qts 10/30 semi syn. in the car at first, drained 4 of that out , added 4 qts 20/50. Now I have a mix of 4 qts 20/50 and 2 1/2 qts 10/30 semi syn. in the car for a total of 6 1/2 qts to fill it.
Last night I put on another new filter and same problem.
What I was trying to get away from with the 10/30 semi syn. was the cold start psi build time and how long it takes the 20/50 to thin at cold temp.
During the winter I usually run a mix of 3 qts castrol 10/30 and 3 1/2 qts 20/50, both dino. oil.
I guess it's what you get for trying to be nice to your car.
I should know better.
Nerd Herder
Originally Posted by triscadek
That's what I'm afraid of.
I take a case of Corona to my mech. every Christmas, I need to ask his opinion too.
Time for a 951 for Paul.
