Sounds like you're considering some stock setup off of a 993. Keep in mind the Porsche recommeded setup for the 968 is 7.5 up front with 9s in the rear for 17's. If you're streeting the car, the 7/9s should be fine, if you plan on doing any track, the 7's can cause understeer with the 9 rears if you push the car too hard.
