Engine Issues - White Smoke
Today is the second time I got a HUGE cloud of white smoke in 3rd gear at about 6300 rpm. By huge, I mean that I couldn't see the car behind me. Last time it happened was a weak ago. Also 3rd gear; near redline.
This means I'm most likely leaking coolant at the headgasket. However, water level has stayed normal for weeks now and I haven't seen any other traces of white smoke. Only in 3rd @ redline on those 2 occasions. Temperature has been normal at about 90 degrees celcius after a hard run. Only other known issue is a small vaccum leak at the brake booster, which has no affect on this.
Interesting, no? Any knowledgeable coments will be appreciated. Thanks.
Well, I'm not too concerned about exhaust gas coming out of my expansion tank. I'm aware that it's a coolant leak of sorts, but it is internal, and an odd situation.
Thanks anyways.
Thanks anyways.
Probably head gasket, as that's the closest the coolant comes to the internals...
I'm 99 percent sure my headgasket is toast, but i never got any white smoke. Of course i didn't hit redline for the last month or so.
Thanks anyways.
Thanks anyways.
I'm pretty sure it is the HG. Just curious if there are any other probable issues I have overlooked.
Btw, there must be something wrong with my turbo; I'm getting no boost.
I have an '86 N/a, by the way.
Milkshake wouldn't cause white smoke. A break in the HG (or even oil cooler seals) which would cause milkshake, wouldn't allow coolant to enter the combustion chambers. The break would have to be pretty damn big, and under those circumstances, I would be losing lots of coolant, not getting adequate compression, running pretty hot, and constantly smoking. The car runs perfectly aside from the 2 instanced @ redline; A bit disconcerting.
I was saying look for it to be headgasket because of milkshake... not the smoke. but smoke could come from headgasket, is what I was referring to. possibly fpr? someone chime in on this, i've heard of white smoke from either fuel damper or fpr.
Like this?????
I've done this a couple times, coming off the rev limiter and quickly closing the throttle. Best we can figure is that I've overfilling the sump a little too much. Still investigating however. No bad coolant fod or milkshake. May have some vacuum issues, but not suspecting head gasket yet...maybe next. Funny thing is that this NA event looks just like a 951 blowing a turbo seal...and both times this has happened folks come running up to see if the "turbo blew."
