Parting: '86 944 n/a in SoCal - SUPER CHEAP NOW! :)
#77
Originally Posted by Bart
Did the inside door levers go out with the door panels or do you still have those? I might be interested in both, if you still have them. (These are the pieces you pull on to open the door from inside.) If you have both, how much? Thanks.
#78
Originally Posted by BigRed
Yep, the clear thing on top of the master cylinder is the reservior. How much again and I'll paypal you ASAP...thanks.
#80
Trevor-
Do you have the dark brown trim piece that surrounds the passenger side window switch? When I replaced mine, I found that it had been cracked and was missing a screw....
#82
Originally Posted by 89AZ944
Trevor-
#83
Originally Posted by father2nate
I feel lazy right now and dont want to go through 6 pages of posts, so.... do you still have the DS door panel? If so, will it fit an early car?
#84
Do you still have the crossmember? If so I suppose I could use it for the core on the 3-piece from Lindsey so I don't have to tie up $400 in a ridiculous core charge. . .
Did I ask you about the center console switches? If you have 'em (rear wiper, mirror switchover, sunroof) I'd probably be interested in those. . .
#85
Originally Posted by shmucklebuckle
Yes, and I don't know.
PS - Does anyone know if the late door panel fits an early door? All I need to switch is the part below the part that you pull to close the door. How confusing.
#86
