Sunday's Top Gear: 928/944/924 hilarity!
Old 12-08-2004, 01:03 AM
  #46
Dash01
Dash01's Avatar
I'm getting like 10kb/sec.....this is taking forever....if you have it log on and spread the wealth.
Old 12-08-2004, 01:54 AM
  #47
kennycoulter
kennycoulter's Avatar
mine downloaded fast, but how do i watch it now?
Old 12-08-2004, 02:15 AM
  #48
Dmitry S.
Dmitry S.'s Avatar
V6 and 3/4.
Old 12-08-2004, 02:36 AM
  #49
dualblade
dualblade's Avatar
man that episode cracked me up! what a great show that was. 926 3/4 was a bit buggy
Old 12-08-2004, 04:12 AM
  #50
shortyboy
shortyboy's Avatar
cant get this vid to work,what types of codecs are you guys using?
Old 12-08-2004, 04:19 AM
  #51
Cass944
Cass944's Avatar
what channel is this show on. people at work talk about watching it sometimes. do i need dish or something. I know i dont have anything euro on time warner.
Old 12-08-2004, 04:35 AM
  #52
Don 944 LA
Don 944 LA's Avatar
it helps if you can open port numbers ( in firewall ) that the torrent client uses.
also, it is propper to leave the file accessable for others ( this is called seeding )
I get up to 180 K/sec on Overnet..
Old 12-08-2004, 04:42 AM
  #53
FSAEracer03
TRB0 GUY
FSAEracer03's Avatar
so far it's been 4 hours and 9 minutes... for part of the time it was going at 1k/s... now it's up to 25k/s and CLAIMS it has less than 3 hours left.... we'll see about that this suuure is fast!
Old 12-08-2004, 05:11 AM
  #54
pearldrum944
pearldrum944's Avatar
Almost 12 hours, and 12%....
Old 12-08-2004, 06:00 AM
  #55
Cpt. Beaky
Cpt. Beaky's Avatar
To use bittorrent effectively you should change the listening port to something random above 15000 or so, as many ISPs are blocking commonly used ports (such as 6881). You are throttled slightly by how much you upload, although you don't need a strict 1:1 download/upload ratio to get high speeds - it's considered polite, however. If you have a complex personal network, it will generally be slower than it otherwise would be. It can take days to make enough connections to download even small files if few people are leaving the file available, but in many cases it is significantly faster than other options.
I strongly recommend using a Bittorrent client. I really liked Torrentstorm (for PC only, AFAIK) as it used Bittornado protocol extensions, but I currently use Azureus because its PnP port allocation works great with my router - so if you are directly connected to the net, I recommend you try for a client that uses Bittornado, unless some other protocol extension has surpassed that in the year or so since I went looking for clients.
Old 12-08-2004, 12:28 PM
  #56
Micah
Micah's Avatar
I laughed out loud numerous times with the 928... wow
Micah
Old 12-08-2004, 12:40 PM
  #57
theedge
theedge's Avatar
Speeds will always vary some, depending on your connection, your ISPs network, and how many seeders vs downloaders. I often see speeds over 100k/sec on big popular torrents.
If you have firewalls (software, hardware) or routers, forward the ports. That will speed it up a lot.
Last I checked, there were a few hundred people seeding this.
Old 12-08-2004, 01:41 PM
  #58
pcarfan944
pcarfan944's Avatar
Anybody want to upload this to a faster, non bittorrent needed server? I think most of us non bittorrent & 56k users would appreciate it.
Old 12-08-2004, 01:58 PM
  #59
Yabo
Yabo's Avatar
once i get mine, i can email it, i said. and it doesnt matter fi your email has size limit, it would be emailing a link.
I will probably have it by the end of the day.
Old 12-08-2004, 02:13 PM
  #60
Nabeel
Nabeel's Avatar
I've downloaded it but now I can't play it. What player are you guys using? I tried DIVX and Windows Media Player...no luck.
Quick Reply: Sunday's Top Gear: 928/944/924 hilarity!
