Bleeding Pwr Steering HELP ! Urgent
Hey I need to change my hose today runing from the tank to the pump what was small drips are now big puddles under the 944. I need some help How do I bleed the system ? With the cap on or off ? They also gave me a fitting with the hose what for ? An urgent response if you could please cause I need to get this done within the next 2 hours.
You bleed the system by filling the reservoir and turning the steering wheel lock-to-lock with the engine running. I would bleed with the cap on. The fitting goes on the pump.
