Removing the oil filter without mess
I've found the plastic grocery bag method the best way to eliminate messy oil changes. There's usually the odd dribble of oil that get's away, but so be it. Also, 944 N/A's (N/A/s only) can be fitted with a 928 oil filter which sits taller and is much easier to install and remove. It will take about .3 or .4 litre more oil on average when using a 928 filter.
