MO30 option,,
MO30 option,,
i think my car (89 944) has the mo30 option on the suspension, the front bar is about 26mm and i think rear is 18mm, any way to know what size torison bars i have?? ( i have maintance records, and dont think anyone modified the car with these bars)
i want to know this as i was looking into stiffer springs and t-bars,, and at the moment i have a little bit of oversteer even with 255 tires in back
thanks
thanks
If your '89 has adjustable rear coil overs and the 18 mm rear bar, you can get away with 200# front springs and maintain the front-rear balance, IMO. You might have the slightly stiffen the rear shock a little bit to keep the car from pushing in the middle of turns, but you will still be in the ball park. Problems start to crop up about balance with non-coil over rears, then the fix ends up being stiffer rear torsion bars which are very labor intensive
It doesn't look like your car has M030. The 474 option is for Koni shocks. Your car has either 23.5 mm torsion bars or 24 mm torsion bars. The factory manuals refer to a technical information Gr. 4 8/89 which apparently says that some 1989 944s were built with 24 mm torsion bars and a 16 mm rear sway bar. Either way, the rear torsion bars are pretty soft, and going to 200# front springs will increase the understeer.
My '89 NA suspension has confused me as well. It has a 26.8mm front sway bar but I don't have the M030 option. That front bar size seems big for non-M030 and it appears to be original (wear and tear seem consistent with rest of car) .... but I have the Koni rear shocks.
