what it looks like when the clutch's rubber center goes (pics)
#31
Hey Man
Originally Posted by Scuba Steve
How about if it doesn't seem to engage where a newer clutch does. It drives fine otherwise, and I couldn't find any junk in the starter hole. Maybe there's an adjustment or something?
#32
When you dump the clutch hard the rubber gives enough to drive off of the three metal tangs.
Also, though nobody added it for a reason in the "how do you park your car" thread, it's also a bad idea to let the weight of the car rest on these tangs before setting the parking brake on an incline, especially if the car will sit idle for a while since the rubber is under a constant twist deformity.
There's a certain "feel" that's missing when you replace with spring centered disc so we replaced mine with original rubber style (87 944S). The original had gone over 100,000 miles.
I rather the feel than my dad's turbo (spring centered)
#33
andy,
thats my brothers old car. Skoot bought it from him. I still have the lug nuts for the cookie cutters and owners manual waiting for scott to pick up.
#34
Originally Posted by AndyK
I wish I had a car lover that wanted to do my clutch for me!
How long did it take YOU Andrew?
Oh, and did Tom's brother sell his car to Scoot?
#35
Originally Posted by 2Tight
Have you adjusted the freeplay at the pedal yet? 1/8" is spec for that and it does make a difference on a worn clutch. It's the last thing I will do when I finish mine tomorrow. Does yours have any clunk at all?
#36
you have to get in the car upside down with you head in the driver's footwell. the adjustment is at the pedal becuase there's no cable to adjust under the hood. there's a little (i think 13mm) nut on the back of the pedal assembly that has to be turned for the adjustment. see if this pic helps you out:
![](http://s89429015.onlinehome.us/manual/2x/11.png)
#37
Tom .. yea i need to pick all of those things up from you. It's just been a very busy two weekends. I'll try to grab them tuesday unless you would be going in the direction of either my or Andrew's house and would like to drop it off
#39
tom, are you talking about my house or scott's house? you're welcome to come to my house on monday as long as it's in the latter part of the afternoon (after 2:30ish)
