Hatch Reseal Pics
#47
Yea, just keep cutting and cutting and cutting. I had one hatch come apart very quickly, and another take twice as long. Just be patient. One of these days me and scott will get ahold of our glass guy to come and seal the hatches we have ready and finish the write up.
#48
Originally Posted by greg rx2
karl
i am about to do this job. question 1 did you use heat to soften the sealant? # 2. how much of a space did you need before you got the wire under the glass? #3 did you just use the tools shown. nothing else? #4 how did you get under the inside lip with the utility knife with glass the way it cuvres esp near the front of the car where it meets the body?
thanks for the great write up with the pics and all.
greg
greg
#1 Once the glass was off the frame i used heat on the frame to help remove the remaining sealant (torch)
#2 Enough to slide the wire through, but quite honestly, if you just keep cutting and cutting with a utility knife, and have someone hold the glass and frame with a little outward pressure, it helps.
#3 Yes, only the tools shown
#4 Cut what you can from both sides, the blade will flex a little, and some places is very tight. The sides are the most difficult, but if you get the top and bottom and at least half of the sides seperated, you can usually peel the frame from the glass....or this is where the wire somes in handy.
#51
Originally Posted by michaelathome
OK..
Here's a bit of info for you DIY people. 3M makes a black single step primer 3M Part # 51135-08681 that you can spray or dab on the glass or aluminum to fill any scratches to the black paint. Michael
#52
Guys, Friday is a holiday here. I REALLY want to tackle this, but the screws (under the spoiler) are just frozen. They do NOT want to move at all, any tips for tackling this?
Also, i found some standard glass silicon/sealer. Would this work fine?
