Mahle filters, anti-drain back valve
Using stock filters the car would take 1-2 seconds on a cold start, using a remote oil filter located below the stock filter...I get oil pressure instantaneaously.
So, the anti-drain back valve in the Mahle (OC-142) filter is not all its cracked up to be.
How do the Bosch filters compare to the Mahle? From reading alot of previous posts i have read to be wary of the Mahle filters. Everyone was comparing different filters like the K&N, STP, Wix...etc. But to my knowledge noone ever mentioned the Bosch.
Adrial, the valve works fine, it's the inverted mounting boss that's draining to cause your 2 second wait - no valve prevents that, only solution is what you have, invert the mounting boss and point the filter somewhat downward.
Sam
Sam
Originally Posted by Porschephile 924
when you say stock, do you mean Porsche filters? I use Porsche filters, and they've got the anti-drain back valve...
