951 Oil Filter Design
This is just a complaint that I have, and one of very few with the 951 I have to talk bad about the engineering of the oil filter design. I know space is very tight with this big four cylinder, but when changing the oil in your car, the filter leaks oil all over the place!!! It seems like there is no way to avoid this problem!! Anybody else want to throw their two cents in also???
The way I do it and usually don't get any oil on anything is put rags, like 2, under the filter just cover the area. I don't get more then a few drops anyways because I take the filler cap off and plug for usually more then 15 mins before I touch the filter.
Yeah, I heard the clutch assembly is a BIG job, luckily I have 123,000 miles, and the original clutch with about 61% left. The owners before me took good care of it, but when it goes, there comes the bills and such.
If you are changing the oil in your spare time, drain the oil pan first when the car is still warm... unscrew the filter an hour later and there won't be a drip. If you're in a rush, get a cut-off 20oz soda bottle and place it under the filter on the housing. put a rag underneath it and let it drip into the bottle and onto the rag.
