banjo bolt thread size for turbo to IC pipe? (xpost @ 944t/s)
I see this has been posted before, search revealed no answers, and the car is 1.5 hrs away from me right now. I wanted to make a custom IC-to-Wasategate (pressure, not signal) line using a thread-in metric to AN adaptor like the XRP ones at the IC pipe and some braided nylon sleeved line running down to the wastegate, right now I have a (borrowed) factory banjo bolt / fitting - but I'm just not a huge fan of adapting the factory rubber crimp-on line to a silicone hose, etc...
Anyhow, I'd really like to pick up the stuff I need up here in Rochester before heading down to work on the car... but I NEED the thread size please!!
TIA
TIA
Well looking at the 11mm x 1.25mm seatbelt bolt, I also have on my desk, I would say no the threads are not as fine as that.
I measured again and it looks more like 6.5-7 threads per 10mm, maybe 12mm x 1.5mm.
