A little feedback, please.....
ARRRRRRRRRRRRRGGGGGGGGGGGGHHHHHHHHHHHHHH......................
My old provider just dropped the danged circuit again - so a bunch of folks couldn't get in......
This is silly.
I need a life..... Or - I need a beer.....
Thanks again for the feedback!!!!!
JD
This is silly.
JD
Nerd Herder
IP / URL resolves OK, I time out after 11 hops- @Washington1.Level3... 4.68.121.172
Load time on the threads seem the same tho-
Cable thru Linux router here Boss.
Originally Posted by Chris_924s
IP / URL resolves OK, I time out after 11 hops- @Washington1.Level3... 4.68.121.172..
Thanks again!!!
JD
I''ll keep tracerouting and note any changes.
My thanks again!!!!
JD
I timed out after 11 hops at ge-7-1.ipcolo2.Washington1.Level3.net, too.
I'm coming in from Knoxville, TN on a Bellsouth.net bridged ADSL connection.
I haven't noticed a performance problem in the past, but pics definitely load faster now.
Dang - thanks!!!!!
Yep - your DNS is carrying the new IP, and the time-out should be at the back-bone gateway, which is where I am hooking in on this circuit.. My thanks!!!
As for problems in the past - tho old circuit took about 14 more hops, and depending on traffic, would go as high as a 312ms response time, if it didn't drop packets,,????
My thanks again!!
JD
My thanks again!!
JD
Originally Posted by marky522
Thanks John, i was doing everything thinking it was my computer again like last time. LOL Its loading fast here in MI on Comcast Cable.
MArk
MArk
Best to you!!!
JD
Originally Posted by ACG
...Singapore.
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
Thanks - it may take me a bit to figure out which route you are coming in - but - THANKS!!!! I just did another upgrade to try to consolidate the circuits, but "Thank you" !!!
Best to you!
John
Originally Posted by Jason_86_951
Seems way faster here! Good work!!
Best to you!
JD
