Where do I find a new / used DME computer
Old 09-16-2004 | 03:15 PM
pologuy's Avatar
pologuy
Talking Where do I find a new / used DME computer
Hey guys,
I am looking for a new or used DME computer, where do I find one?
I looked at paragons website and cant seem to find one.
Is this an easy thing to replace myself? Or do I pay the garage to do it?
Thanks as always.
Old 09-16-2004 | 04:37 PM
Jfrahm's Avatar
Jfrahm
You probably mean the timing belt. IMO Putting the belt back on a tooth off cannot cause this sort of behavior. What sort of car is it?
Old 09-16-2004 | 04:56 PM
Legoland951's Avatar
Legoland951
DME what year? Ebay prices have been coming down for those....
Old 09-16-2004 | 05:06 PM
pologuy's Avatar
pologuy
1986 944 NA
Old 09-16-2004 | 05:14 PM
Dash01's Avatar
Dash01
Before you replace the unit, why not re-solder the joints? I'm told that often cures the likely faults, and it's a cheap fix. Then, if no luck, start considering more expensive options.
Old 09-16-2004 | 05:33 PM
pologuy's Avatar
pologuy
Well, for one, I am totally mechanically illiterate......
Is there somewhere on the net that shows how to do that?
Old 09-16-2004 | 06:00 PM
Dash01's Avatar
Dash01
Search Rennlist forums for keywords "DME too hot" for an excellent thread and cross-references, and also check Clark Fletcher's website about resoldering the DME relay.
Your problem may be the relay, as opposed to the DME itself, as our original relays reportedly have a checkered past. Porsche has an upgraded DME relay for <$20 at better parts places, such as Zims, Paragon, or BMA.
I'm having some non-start problems, so have read as much as I could find lately on DME/KLR/relay issues. After corresponding with folks much more knowledgeable than me, I surmise that many people wind up replacing DMEs needlessly. In other words, they spend several hundred dollars to replace a unit that only needed a few solder joints refreshed in 5 minutes with a $10 Radio Shack soldering iron. Again, I'm just now learning and claim no personal expertise whatever, but folks who know about these things have suggested the solders around heat sinks, such as the ignition driver, and/or ribbon cable connnections, are common failure points: Re-flow the solder, which can crack with age on these old cars.
Somebody else replaced the ignition driver (which reportedly tends to overheat and stress the joints) with an inexpensive transistor.
At the very least, do continuity checks with a multimeter.
But, with all things electronic, make sure you are properly grounded.
First, disconnect the car battery before doing anything further.
Old 09-16-2004 | 06:04 PM
pologuy's Avatar
pologuy
Hey thanks.
It isnt the dme relay, I replaced that and it wasnt the problem....
Old 09-16-2004 | 06:12 PM
Legoland951
I was thinking about bidding on this one as a spare but since you need one.....
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
Old 09-16-2004 | 10:23 PM
pologuy's Avatar
pologuy
LOL, thanks, its already on my watch list, LOL
Old 09-16-2004 | 11:40 PM
Kevin Baker's Avatar
Kevin Baker
polo, did the shop finally diagnose the problem to be related to the DME?
Check with the following:
www.porschepartsoftexas.com
www.partsheaven.com
Or you can check with a local junkyard to see if they have an 86-88 n/a that in the yard. The unit is very easy to remove. Pull back the carpet on the passenger side, take a phillips head screwdriver (not a hammer) and remove the wooden board, the DME is under the metal brackets, unplug the big computer cable from it and remove. When you go to install it in your car, disconnect the negative battery cable before you do this.
Old 09-17-2004 | 01:35 AM
ckkrause's Avatar
ckkrause
...or you can buy the I have! I have DME from an '88 924S (identical DME as in '88 944 n/a). Already packed and ready to ship. It came out of a strong running good idling car that got T-boned and is now a parts car. $100 OBO...
-CKKrause
Old 09-17-2004 | 01:40 AM
Legoland951
ckkrause, I think the 88 924S has higher compression than his 86 n/a thus the chip may be different.
Old 09-17-2004 | 01:56 AM
ckkrause's Avatar
ckkrause
Legoland-
You are right, I'd just had my evening cocktail and I read '88 rather than '86... Now I think I'll have another!!!!
-CKKrause
Old 09-17-2004 | 08:28 AM
david fracolli's Avatar
david fracolli
I have one out of an 85.5 N/A.
I'll take a hundred even for it.
Quick Reply: Where do I find a new / used DME computer
