Screwed - Cannot Open Passenger Door
#31
Got Nothin'
Geo
Thanks. The pix will help. Also does anyone have an exploded view of the door lock assembly?
That may also help me open this can of worms....
Another fine mess.
Another fine mess.
#32
Hey Man
Pete, Maybe these will help you:
![](http://forums.rennlist.com/upload/handle2.jpg)
Part No. 2 in the top pic and No. 9 in the bottom pic are the ones that will release the lock mechanism the easiest. Good Luck, I would still try going in through the lock lifter hole at the rear of the door panel.
![](http://forums.rennlist.com/upload/lock_rod_copy_copy1.jpg)
#33
Pete,
I think 2Tight is right about removing the lock actuator button and poking sometihng down there to see if you can free it up. But if you have to cut something, I'd cut the inner door panel. Maybe you remove all the screws you can reach and cut the panel around the screws behind the door frame. Then you might have a chance of repairing the panel.
Good Luck.
Good Luck.
#34
Got Nothin'
Thanks for the exploded view. I need to find a way to get the lock mechanism free from the door handle (part 9) once I do that, I am sure I can unlock the door. I am not sure where part 2 in the top pic is, or what it is for that matter. Is that showing power locks?
#39
Got Nothin'
Originally Posted by nineeagles
sorry....I didn't realize that the door was locked closed......my oversight....
#41
One of the easiest ways of performance upgrade is reducing weight, by not being able to open the pass door you've done a unplanned performance upgrade. Stop groaning and enjoy the new found acceleration.
#42
Hey Man
Originally Posted by PeteL
Morning bump...door still closed....
#43
Dang Pete - I've looked at the drawings and gone over the procedures I wrote and I can't come up with anything other than cutting the door panel to gain access. I'd keep trying the slim jim though - at least until you can source a replacement door panel.
#44
Got Nothin'
Originally Posted by 2Tight
I hope posting this quote doesn't become as common as morning coffee. The obviuos solution is abandon all your friends and drive alone.
#45
Is it time for stupid suggestions yet or have all of the stupid suggestions been made already?
I was in an accident (in a Crown Vic) a couple of months ago, hit from behind. The door wouldn’t open so I had to kick it open from the inside. Have you tried to pull the inside handle and give it a good hit with your shoulder. You may break your shoulder if you try too hard or are in bad shape. Maybe it will work maybe it wont.
