Need HELP now!!! I'm pulling a 924S motor and I'm stymied
![Unhappy](https://rennlist.com/forums/images/icons/icon9.gif)
I am pulling the motor from an automatic '88 924S and I've got the motor hanging in midair, with absolutely nothing connected to the motor other than inside the bell housing. For the life of me I can get it loose. I've removed the starter, dropped the crossmember, and all 4 bolts on the bell housing and I have a gap of an inch or two between the bell housing and motor all the way around and it won't go further. I even unbolted torque tube in hopes that it would separate between the bell housing and tube, but no luck there. What's the secret or am I'm just a doouff.... I have to return the lift tomorrow, so please heeeeellllppppp!!!!
Thanks for your reply!
-CKKrause
-CKKrause
It's similar to a C clip except it has a center piece that makes it an E clip.
It snaps onto the input shaft just in front of the damper (part that is used instead of a clutch and pressure plate). The torque tube will not pull back until this clip is removed.
BTDT.......Paul's right, you need to reach thru the starter opening, remove all nine of the bolts aroung the starter ring/flywheel/damper, and only then will the engine seperate from the bell housing, leaving the damper on the front of the torque tube. So, you will be leaving the bell housing in the car with the damper on the torque tube, so bolt bellhousing back up to the torque tube. After you get engine seperated from the bellhousing (splitting at flywheel/damper), then, and only then, will you have access to that E-clip on the forward end of damper (you can't see it until its seperated). HTH
Great!! I see the bolts and I'll do that first thing in the morning!! I thought I was going crazy.... Thanks again for all your replies!
-CKKrause
-CKKrause
I hear you! I've mostly been doing 911's until this year and I can drop a 911 motor in about an hour and half....so this was an all day affair with no conclusion...very frustrating!!
THanks again!
-CKKrause
THanks again!
-CKKrause
Originally Posted by PaulStewart
The first time I did one of these, I had to call the dealer!!!! That was long before the Internet was available....
I'll never admit to the outcome of the first one I did..........at least it was a parts car..............did'nt want that torque tube anyway.
Sunday Morning...motor came out in 1/2 hour... One more success for this Board!!!! Thanks in particular to Paul Steward for sending PET diagrams!!!
-CKKrause
-CKKrause
