15 x 7/8 Fuchs questions
Hi all, new guy here. I tried the search but after page 7, I decided to post. I've got a couple questions about Fuchs wheels as I am looking to fit them to my VW. I'm wanting to put some 15 x 7 and 15 x 8 Fuchs wheels onto my car. Do they make these in the late (53mm) offset? With 25mm adapters from H&R, they would be able to fit under my fenders with an effective offset of 28mm. I know they make them in 16 x 7 and 16 x 8 but would prefer to put 15's on my car, mainly due to cost. Any help is appreciated.
Hates Family Guy
Fuchs wheels are only available in early offset.
I've heard of using 6" Fuchs, cutting off the rear portion of the rim and attaching another, effectively creating a late offset Fuch wheel, but that would be very expensive.
Originally Posted by Macfreak007
What kind of VW are you trying to put fuchs on just out of curiousity?
Nerd Herder
There is a company out there taking the Fuch's centers, removing the rims and converting them into 3 pc. wheels for late offset. IIRC they are about 1100 each- and YOU send your early offset Fuchs wheels to them- your choice of rim width.
Yes, Vurginia. you can have late offset Fuchs. if you have a spare 5 grand laying around for the conversion
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
Yes, Vurginia. you can have late offset Fuchs. if you have a spare 5 grand laying around for the conversion![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
![cherrsagai](https://rennlist.com/forums/graemlins/drink.gif)
Hates Family Guy
Originally Posted by VooDooRay
1984 Jetta Coupe
brand new front and rear hubs (un-drilled) - these hubs will fit mk1-mk4 golfs (different spline`s). these will be un-drilled and can therefore be machined to fit any wheels on a vw. (they can be supplied drilled if required) iro porsche 5x130, audi 5x112, bmw 5x120 etc etc therefore they will fit straight on without using any form of adaptors. the hubs will be built to group a spec by a company that manufactures formula 1 parts.
dave.luben@equitas.co.uk - 07890 382511 (Bookham, Surrey)
Hates Family Guy
Follow-up question...were there any 15" wheels offered in the late offset? Or, which 16" wheels were offered?
Another thought would be to use Audi Fuchs wheels. They look similar and you could use late model Passat hubs and brakes. 5x112 bolt pattern.
