pulling dents
i have a dent in my car that looks to be easily pullable with some sort of suction cup tool. i got one at autozone but the surface area was too big. any suggestions on where else to find a dent pulling tool that doesnt require drilling? the suction cup worked well for one area, but there is one spot that requires something a little smaller than 4.5in.
Well hello ryan!
Fix your sig.. that 944's gone!!
(not to remind you or anything)
Not sure about the suction ones, but aren't there some magnet ones too that are available? probably a little more costly though...
I'm not sure how it's done. But I have heard that you can use dry ice to pop out dents.. something about letting it sit in the sun to get the metal hot then you put the dry iceon the dent and it contracts the metal and pops the dent.. HTH..
I go to a local paintless dent repair guy who pops em out for $25 or $100 a hour. He did 8 for me in an hour. I do not have the experience to do it myself so I prefer to take it to the pro.
http://www.dingking.tv/?source=gg
I must say that I was pretty impressed with just how well it does work. I've used it to remove several small ding dents, and have pulled out most of a couple fairly nasty dents that, while they may not be perfect, it worked well enough to get the damage to well within glazing putty/body filler range. This tool uses a hot glue on a pulling stud. glue comes off car by just using a couple drops of their solvent (isopropanol alchohol). Leaves no scratching/marring in paint (need to wipe off solvent quickly/ possibly a little polishing compound), if there is any body filler under that pulling stud, it can, and most likely will tear some of that putty out. Now, I've only used it on a car that I have plans to repaint anyway, so I took a "well see" attitude. I was pretty impressed, for such a cheap/cheesy tool.
If you really want it done perfect the first time.......I agree with Bruce.
Good luck
I dunno about those things. Any of those "only sold on TV" Ronco-esque things just scream "rip off" to me. If it worked for you, good I guess. I'd love to know how it doesn't rip all your paint off or chemically discolor it though. Why not just do the dry ice thing or just yank the panel off and tap it out from the inside?
I'd much rather get behind it, to work out a dent if possible, but we all know thats not always possible or desireable. Dry ice method indeed has its limitations also.
Granite,
Did You use it on repainted car ? I have many hail dents on my car and plan to go with glue method. What do You think ? Anyone tried www.dentout.com products offered by pelicanparts ?
Originally Posted by tkacki
Granite,
Locally there are guys who pull door dents and dings for about $20 each... I had one that was the size of e quarter but it had creased down the door about 8 inches... after he quoted me $50 to do that one, it is absolutely gone...
In my opnion, its not worth the trouble to do it yourself.
Hi,
Over 100 dents on my car after hail. Mostly on roof and hood. Many small dents - 10 mm diamater and 0,5 mm deep (not noticeable if car is not waxed) and about 20 nasty 20mm width and over 1mm deep. Plan to start with glue method before I buy proffestional PDR kit (tools).
To many dents for proffesional repair.....Have to do it myself.
Any other method to remove such small dents ?
Regards,
Regards,
