Removing cruise control
It doesn't work properly, I don't plan on using it anyways, how do I get rid of it? Is it basically just pulling everything off, or does the cable to the throttle need some special attention?
Once out, I will be mounting the adjustable fuel pressure regulator (with the Lindsey Racing rail kit) in it's place.
Originally Posted by spangle
Would you like to sell it? Are you also replacing the steering wheel stuff?
