Getting that fan switch off, F*@K, need a tip
Official Bay Area Patriot
Fuse 24 Assassin
Fuse 24 Assassin
How the hell do you get the damn fan switch off?!?!?!!
I tried a 30 mm wrench, socket, crawled underneath the car to do it and I still couldn't get it, ****!!! Tedious
Andy
Andy
Fuse 24 Assassin
Fuse 24 Assassin
no universal joint. I have one, thanks for the tip, but theres still VERY Limited space and I don't know whether to remove it from above or below the car still. If anyone else has done it, lots of feedback would be greatly appreciated!
Andy
Andy
I had to take the fans off (only 6 screws - infact only 5 in mine) and get to it from underneath with a big spanner.
Wouldn't bother draining the coolant - just have the new switch handy and do a quick change - you'll only get as wet as you would draining it anyway.
Also, i put a new low temp switch in and it is rubbish - the fans stay on as soon as it warms up and never switch off - i believe you need a low temp thermostat for it work right with a low temp switch - or a stock switch as it should be (that's what i'm off with).
Originally posted by NZ951
No fans off, just take the right hose off and get a very deep socket...
Got mine from above very easily after removing the air box on my S. I know the non-S/Turbo is different but it may be worth a try.
I also noticed that you need an extra deep 30mm socket to reach the hex on the switch for air-con equipped cars. The non-air-con switch is shallower.
Cheers,
Neil
Cheers,
Neil
