starting woes revisited
Official Bay Area Patriot
Fuse 24 Assassin
Fuse 24 Assassin
Well, its been a couple weeks since the new battery was installed. This morning my starter was once again doing the same thing. I haven't gotten a chance to go down and take a glance at the starter really to see if the cables and connections are corroded.
Anyways, I stumbled across a 12 volt starter relay from Performance Products. Has anyone used this? Will this solve my problem also?
Andy
Andy
Fuse 24 Assassin
Fuse 24 Assassin
UPDATE!
I just came back from my 10 minute break and the same thing happened. No start. However, when I kick the dead pedal board while turning the key the car will start after a couple slams. WTF is going on here, my 84 even did the same thing...
Andy
Andy
Fuse 24 Assassin
Fuse 24 Assassin
exactly! very frustrating...you can hear a click like the starter is attempting to turn but won't. Give that dead pedal board a couple kicks and she starts turning and starts right up. I dunno about you but I treat my cars like women and I don't like smacking them around, the 944 is like the first i had to kick the board to get it started both 84 and this 86.
Andy
Andy
So you don't like smacking your women just kicking them. Anyway if the you can here the starter trying to turn then you know it's getting the signal. I would ck and clean both battery cables and the big cable on the starter. Also ck the engine ground and make sure connection is clean and tight. And, make sure the cable isn't full of corrosion. When you are under the car make sure the cables arn't hitting the starter housing. (grounding)
Fuse 24 Assassin
Fuse 24 Assassin
thanks Jim, this weekend I get a chance to get under the car, I'll start cleaning then. And nope dont' like kickin 'em either, just lovin'.
If all else fails this post will be back with a lot of these
Andy
Andy
Fuse 24 Assassin
Fuse 24 Assassin
I cleaned the cables before I did the battery, COMPLETELY. Obviously no resistance there....it has to be the cables at the starter....I'll let you know Jim. Thanks again
Andy
Andy
