Whirling/humming noise @ >75km/h?
mine started off like that. it got louder and began to make the noise at lower speeds. now, while coasting <5mph, it clicks. I believe it is the right rear CV Joint.
It's not a constant sound. It's more like: Whur whur whur whur whur whur. The faster u go, the faster the whur whur goes.
So something like suspension, or maybe brake calipers I guess...
It's hard to say where its coming from, but possibly the rear.
If it doesn't change when you hard corner either way then it's probably in the tires as dave suggested. If in doubt put the back of the car in the air and get a stethoscope. Listen to the trailing arm closest to the wheel brg. If you don't have Lsd, just pull the handbrake cable on the turning wheel side and the other will take off.
The rear are 245's the front are 225's. Don't have the car with me right now, but if I remember the wear wasn't too bad on the rear. Maybe half way through it's life or a bit more.
