Does K&N oil filter get oil on parts downflow?
Recently I bought a K&N filter for my 944. I have no illusions about better performance, its just that I figured I'd save a few bucks with the reusable filter. After about two filter changes I break even with the K&N.
Anyway, I was talking to a friend today, and he said the oil from the K&N filter can screw up sensors downflow from the filter. True? Should I toss the K&N filter?
Mark
Mark
You will only have that problem if you do not let the oil dry fully when cleaning and oiling it. Just let it dry fully and you should be fine. I installed mine without it fully dry and it didnt do anything. I just cleaned it out.
I've read that this might be a problem on BMWs.
My guess is that it could affect cars with hotwire MAF sensors. Early 944s use a flap to sense air flow and I doubt this would be affected by oil. If later models use a different MAF sensor, it might be a problem. And, of course, just downstream of the air flap, there is a hose that vents the timing case, so theres plenty of oil sucked in there.
I ran one on my 83 for a year and a half with no problems.
Yeah, you mean the K&N air filter gets oil on sensors, right?
I use both the K&N oil and air filters. I've had the air filter for about 50,000 miles and no problems yet. But who knows, someone may have over-oiled the air filter and it caused that person huge problems. I doubt that it hurts the car if used correctly though.
