a/c compressor removal and some questions
hey guys...i have no idea which hose is the a/c fast idle hose xcept maybe the two hoses that attach to the compressor...am i right? and if so which one...and also...to take out my engine it looks like i'll have to take off those two hoses to the compressor or just remove the compressor itself...but if that's the case what is involved in "recharging" the compressor system, or actually what's involved in updating the system to use the new freon? thanks
jake
jake
Where are the bolts that hold the compressor in place? Does any other component have to be removed before I remove the compressor? I need to replace the seals/o-rings because my compressor leaks out all of the freon in 2 days.
My car is without A/C and I can't take the heat.
hey jim...clark's garage refers to an "a/c fast idle hose" in his engine removal manual...i was unclear as to what that was as well..
oh and poindex...there are two bolts that hold the compressor in place...actually three when you think about it because one is connected to the alternator...but for the main bolts on the compressor there's one up top and then one down below...the one down below you'll have to use two wrenches or a wrench and socket wrench because the one on the bottom has a nut behind the compressor housing attached to it
If you suspect the compressor o-rings are bad, keep in mind that virtually every connection of a hose to a component in the entire a/c system also has an o-ring. Are you changing them all?
Re: a/c compressor removal and some questions
You don't need to remove this hose in order to remove the AC compressor.
Ideally you should take the car to a shop to recycle the old freon. In reality, if you have a leak, there probably is hardly any freon in it now. You can check by depressing the shredder valve in either the high or the low side ports, and listen for 'psssss'.
Important: read related posts regarding safty tips - AC systems can be dangerous.
