SOW GTG this weekend?
#33
Originally posted by xsboost90
if'n you guys meet up, email me let me know in case i lose this post, i might join you guys.
#35
Cleveland Rocks
Originally posted by Dan87951
Its a fuel pressure regulator from my 87 turbo, I took it off the car when it had 43k on it. So far Wade I'm a for sure, Sam is pretty much a for sure I think, and MR 103 aka Matt, i'm awaiting his response... we will have a good time no doubt, I even sent Cory a PM.
The reference to the FPR was because UD was having a hesitation problem with his car a few weeks ago and we switched ours out to see if that could be it. Both of ours work fine. but thanks for the offer anyway.
Explicit directions;
I-75 to the Franklin-Springboro exit (SR 73)
Go west on SR 73
Go for about 3mi. and you will see a Speedway on your left, Subway on your right. (Don't make any turns. SR 73 goes left at the Speedway, but you want to go straight). Shortly after the Speedway you will cross a bridge, and you will go left at the first light on the other side of the bridge (it will be Miami Ave., or possibly Oxford Rd., depending on which map service you used. They list that as different roads sometimes).
Go 3-4 mi. and you will come to a stop sign. Go straight thru it (after stopping, of course) and you will cross another bridge, and go thru an "S" turn. Shortly after the "S" turn you will see a street on your right (Twinview Ave.). My house is the third one on the right past Twinview Ave. It is a white two story with four tall columns in front. Address is 8524. It is really easy to find, only the one left turn after the first bridge, just thought I'd give a few landmarks and hints to help. Should you get lost, my home # is 513 727 9641.
Let's make it about 1:00-ish. I have some errands to run in the morning, should give me plenty of time. If you should happen to arrive earlier, just take a seat on the deck in back of the house, I have no problem with that. See ya'..............
#37
Budding Photographer
OK Wade, can you stand (2) Goodson brothers with guards red cars??? I just talked my older brother into coming. I've talking about how much fun 944Fest was this year and hanging out with all of you, he now wants to come this weekend along with me. Exactly how much room do you have on your floor Wade?
He's got a 911 cab by the way.
#38
Originally posted by 944pete
If anyone has a wrench that fits the oil pressure sender, bring it.
I need to replace the crush washer so my oil leak can go away. (I hope).
#40
Originally posted by tifosiman
what size is it?
what size is it?
Maybe I'll start a new thread to find out what size it is.
Cory, I have room and your welcome at casa del Pete anytime.
#43
i wonder if thats what my leak is...hmmm..
I hope it fixes mine, the oil is coming from that area. I did all the front seals and the oil cooler housing is not leaking.
#44
I'm in but I can't make it till after work 6pm and xsboost do you think that the inner bushings that are on that sway are good northland has the outer. So I could just pick up those. Anyhow porsche don't leak oil they make there spot. I think mine has a bladder infection tho.
#45
Wow looks like there is going to be a good turn out sweet. Cory is will your brother going to have the turbo or the cab this weekend?
Wade you have enough room for all these cars?
PS: "Mr 103" can't make it....
