Can't Unbolt The Starter!! edit: FINALLY GOT THOSE BABIES OFF!
Old 07-05-2004, 06:20 PM
Jakerx
Hitsquad Ninja
Jakerx's Avatar
hey...i got my impact wrecnh down there (only with a universal joint)...but still no luck with it either...i have yet to get it loose....arg
Old 07-05-2004, 06:36 PM
Jakerx
Hitsquad Ninja
Jakerx's Avatar
coud someone explain this breaker bar thing?
Old 07-05-2004, 09:07 PM
Dave in Chicago
Dave in Chicago's Avatar
I swear by PB Blaster as a bolt loosening spray. Soak it and let her sit. Doesn't hurt to try a little tightening before loosening too. FWIW.
Old 07-05-2004, 11:34 PM
Danno
Danno's Avatar
"19MM socket on a 1/2" drive with a 16" breaker bar. "
"coud someone explain this breaker bar thing?"
Breaker bar is like a ratchet wrench without the ratcheting mechanism. Just a swiveling 1/2" drive stub. The long handle, 16-18" gets you get additional leverage. Then add 2-feet more with a pipe over the handle. Combined lenght of 3' will get you generate 200lb*ft easily.
Harbor Freight breaker-bar
Old 07-05-2004, 11:35 PM
PorscheDoc
PorscheDoc's Avatar
Grow stronger. No seriously, slap a 2 foot pipe on the end of your rachet for extra leverage, works just as well as a $20 breaker bar.
Old 07-06-2004, 12:39 AM
Porsche-O-Phile
Porsche-O-Phile's Avatar
I let them soak for about 3 hours (went out & had lunch), came back and cracked 'em right off with a 19mm box end. Pretty easy. This was about 2 hours ago
Old 07-06-2004, 10:53 AM
Jakerx
Hitsquad Ninja
Jakerx's Avatar
hmmm ok...ive heard about liquid wrench and pb blaster...which do you think is better for the job
Old 07-06-2004, 11:11 AM
Porsche-O-Phile
Eat spinach?
89magic98
In the Sink
89magic98's Avatar
PB Blaster.
Old 07-06-2004, 11:23 AM
89magic98
In the Sink
89magic98's Avatar
[/B]
Hmm, a chrome vanadium breaker bar... J/K
Old 07-06-2004, 04:54 PM
Roy LaZelle
Roy LaZelle's Avatar
I too had problems getting the starter off. Tried lots of different approaches. The impact wrench and universal joint just rounded the hex head bolt. I ended up using a 19mm combo wrench on the hex head bolt, and smacking it with a 5 lb. hammer. The Allen head bolt had to be cutoff with a Dremel and a cutoff wheel. I used anti-seize on both new bolts when I put it back. Good luck. --Roy--
Old 07-06-2004, 11:04 PM
Jakerx
Hitsquad Ninja
Jakerx's Avatar
ok screw liquid wrench...thats 2 dollars down the drain...i guess im going to have to try the breaker bar approach and if that doesn't work use a dremel and cutoff wheel? could someone explain that to me? thanks
jake
Old 07-07-2004, 10:08 PM
Jakerx
Hitsquad Ninja
Jakerx's Avatar
YEAH baby FINALLY GOT THOSE BABIES OFF...i should've just used a breaker bar from the beginning...18 inches did the trick...came off in like two seconds...liquid wrench was worthless
Old 07-07-2004, 10:11 PM
bloodraven
bloodraven's Avatar
lucky sonuva.....
Old 07-07-2004, 10:55 PM
Chris_924s
Nerd Herder
Chris_924s's Avatar
PB Blaster- I swear it's devils spit.. a day of soaking and a light hammer touch- It's gold Jerry, just GOLD!
Quick Reply: Can't Unbolt The Starter!! edit: FINALLY GOT THOSE BABIES OFF!
