block ground location? (edit: found it...now cant get to it)
Hitsquad Ninja
![Unhappy](https://rennlist.com/forums/images/icons/icon9.gif)
hey...im having a hard time locating the ground that goes from the block to the firewall? can anyone give me some specifics on location or maybe a picture? thanks
jake
jake
Follow the wiring-harness. You'll find the elephant trunk rubber snout coming from the firewall. Follow to where it splits off to go to the injectors. Continue on the other branch and you'll see two big brown wires. Follow those wires to where they bolt onto the block & bellhousing underneath the heater valve.
Gee, you waited a whole 31 minutes before you wanted an answer.
If you start looking at the negative terminal of the battery, you will see that the cable goes right to the chassis, then it goes directly to the engine.
Sorry it took me so long to answer! :-)
gb
gb
Hitsquad Ninja
haha i know it was a short time but i was in a hurry since i have my laptop here right next to me working...thanks a bunch though guys
Hitsquad Ninja
man i found it and all..(thanks again) but it's so hard to get to...any tips on unbolting it? i tried a socket wrench and then trying to get a normal wrench down there...i get it on the bolt but i can't move around at all to screw it loose...=(
It's really easy to drop that nut. When you do, it goes smack into the bellhousing!
On my car, there is a 10mm bolt on the block and a 13mm nut on a stud in the bellhousing. IIRC.
Nerd Herder
