Help My Engine Died On The Highway
Hitsquad Ninja
![Exclamation](https://rennlist.com/forums/images/icons/icon4.gif)
okay i was driving along the highway at 70 mph and all of a sudden my engine goes out...it doesn't make a sound or anything it just turns off, so i stop on the shoulder and try starting again...no luck...u know that sound you normally hear like the engine is choking or something when you start a car normally? i don't hear that sound...i just hear this kind of electrical monotone constant sound thing...any ideas or suggestions?
The electrical monotone sounds like the fuel pump. If it just died suddenly without blowing up its eithr fuel or electrical. My guess is electrical
Nerd Herder
I think MichelleJD had the same issue on her 951- You may want to PM or e-mail her. I cant remember exactly what it was, amd I'm not going to guess.
What did the guages do when it quit? any warning lights pop on?
Lazer Beam Shooter
Chris i found out that MichelleJD problem was her Pipe thing falling off the turbo or something. Doesnt work for an N/a ![Frown](https://rennlist.com/forums/images/smilies/frown.gif)
It could be a turd like mine and one of the sensors went out. Do the tests and save money instead of just guessing.
My guess is DME relay. Common problem with the symptoms you are describing. Luckily its not expensive. Check this first before exploring more expensive options.
Here is one easy way to check if your valves are ok see if the belt is still on. If it is then check if it's at TDC. It sounds to me like it has bent valve no compression so it turns over freely.
Nerd Herder
Top Dead Center. Check the inspection hole at the top of the bellhousing- (It's a little difficult to see, but it's there) inside on the flywheel there is a marking for TDC.
Originally posted by azndrvr447
ya when it quit some warning lights came on...i'll go ahead and check the dme relay today...but sebs...what's a tdc?
The timing belt broke.
Lazer Beam Shooter
Oh nelly Socal dont scare us like that... but with Texas sand and heat and rattle snakes in the timing belt cover... it is very well possible.
"doesn't make a sound or anything it just turns off"
"i just hear this kind of electrical monotone constant sound thing...any ideas or suggestions?"
My suggestion is that the timing belt should have been changed a long time ago.
Oops! Too late.
