1985.5/2 944 suspension transferable with the S,S2,Turbo suspension?
Hello! I am planning to put in KW suspension. But it says it’s for the 1986-1991 S,S2,Turbo and I’m trying to figure out if it’s the same as a 1985.5/2 suspension. (this is the later year car with updated dash etc)
This is a 8v car!!
This is a 8v car!!
I will be upgrading brakes, and I’m doing custom wheels in the future as well. Why would I need to change the hubs? Geometry difference? Or just to space stuff out for wheels?
the hubs are completely different from 86 vs 87+.
in order to do this swap in question the only part that would be reused on your car would be the control arms, calipers. and wheels.
you would need the late style struts, spindles, hubs, brake discs, and strut mounts.
offset on the front is determined by the control arm length, not the hub.
