84 Na headlight switch issue
Recently replaced headlight switch and since installing new (used) switch I am unable to turn on taillights, fog lights and dash dim. Headlights will only raise up with switch but won’t fold. Any help would be greatly appreciated 🤙
Cameronjames (06-26-2024)
Yes that wire is what originally caused the issue. Wrapping split close to base of connector. I thought I fixed it but I guess not. Thanks for the tip 🤙
All the power for the lights go through the switch, not a great idea. This Hella setup takes the power from the switch.
Hella Universal H4 Headlamp Wiring Harness With Relay System 130/100W eBay
I have the old switch which still functions but it is missing the dimmer wheel and the actual toggle switch for headlights so later tonite I’m gonna swap them and see if it’s the switch or connector
Tiger03447 (06-28-2024)
You could also switch to 7” LED headlights(Jeep?) and decrease the load on the switch. I’d like to know how to install a pair of extra relays to the circuit to prevent any more underdash fires in my 83 944.Dash is out, BTW .😀 TIA
Tiger03447 (06-29-2024)
If you buy or build a headlight harness, here's a good set of instructions for installation:
Cheers
Cheers
