No power to left foglight?
The left (driver side) foglight get's no power. The other side works fine.
But the driving lights and high beam works on both sides.
I have checked the fuse.
Any good ideas where the wiring might be broken or where the wiring goes from the left bumper lights?
Thanks!
Thanks!
I think you have corroded connectors. I had to replace both on my foglights last night on my NA because the connections were rusted and eaten because of the salts on the back East roads. I replaced my fogs the same time. Goto Lowes or Home Depot, buy some connectors that can be crimped with a wire tool. A trick also would be to clean your foglight connectors off with a wire brush and spray electrical cleaner on the contacts while you're brushing them. Use a di-electric grease afterwards on them to ensure you'll never have the same problem again. And, call me in the morning if they don't work after that
Andy
Andy
