Stock Alarm
Lazer Beam Shooter
Dude i use any key for my stock alarm. My door key works, my ignition key works, the jeep key might even work. I imagine all that thing needs to do is be turned. Close the car doors and turn the alarm so that the keyhole is horizontal. Then open a door
i have hte little light next to the steering wheel, and i have a plug with a box near my dme, does that mean i should have the alarm? its not plugged in down by the dme
I didn't have a key for my roll around tool chest and the locksmith cut a key going on the template of what the key should be for that lock and it worked! Ask a locksmith if he has the template for the alarm lock.
If you have no luck, I'll ask the locksmith at work.
Michael
Michael
well then, i don't know whats up with my alarm, because my module isn't plugged in. i plugged it in, and it didn't seem to be any different.
How do you usually activate the alarm? (and then get it to go off?}
It will start with the alarm module unplugged (at least an 84 N/A will) Your alternator won't charge though. I now have a brand new alternator and a perfectly good spare to show for it......
