I used the one out of an S-2. You have to use the S-2 side plate adapter with the filter and run lines down to the front scoop. The S-2 mounts it in the Rt front fender area. I preferred mine in the front lower air scoop. I also fabricated a screen in front of it to keep the rocks out.😀
Photos of external oil cooler installation on RH side. Oil cooler, hose, and fittings from BAT Inc, Sarasota, FL; inlet air ductwork from ????, do web search on oil cooler inlet ducts.
My observation is the external oil cooler with the bypass adapter could be undersized for ambient temperatures.
This unit is sourced in UK, where the average daily temperature does not exceed 70F
