Tightening U joints on steering shaft
I am experiencing much play in my sterring wheel, which becomed worse at higher speeds. I believe that there is play in my steering shaft because whith the car sitting, engine off, I can turn the wheel slightly in both direction (about a centimeter or 2). Is there any way i can chech the steering shaft for play? Can the U Joints themselves become loose?
Christian
Christian
Lego,
Hmm, I didn't know ball joints would cause play! My mechanich happened to mention a bad driver's side ball joint and tie rod end. As such, I bought a ball joint kit from rennbay, and tie rod ends. However I havnt had the time to do them yet.
I guess I should get in gear, and stop ***** footing.
-Christian
-Christian
Sounds like the steering shaft to me. I replaced ball joints and tie rod assemblies and still had that play in the wheel.
You can stick your hand down in front of the brake fluid reservoir to grasp the shaft and twist it to check for any play.
If your car has power steering, I have a nice used steering shaft that I'll sell to you cheap. PM me if you're interested.
I bought it by mistake when the eBayer said it would fit "all 944 cars 82-91." Manual shafts are about 1cm longer.
