Quick alternator question!!
Im in the middle of installing Dan's upgraded headlights on my 924S...only ran into one problem which involved a broken voltage regulator (my own fault). Anyways i just put the supplemtntal ground strap on, now i am putting on the positive feed to the alternator. Which stud do i put the positive feed onto?
Is it the stud with the blue wire attached or the larger one below it? Just want to verify to avoid blowing anything up.
