found coolant leak(what the)
8th Gear
I had a major coolant leak the other while driving and shut it down instantly.Had just left work so the engine was not even at operating temperature.Had the car towed and finally got into it today.Found the strangest thing wrong with it.The hose from the heating regulator that attaches to the engine came off with the pipe stud still attached.The pipe stud just pulled out of the housing on the engine. Has anybody else had this happen? Dose anyone have a idea on fitting the pipe sleve back into the housing or should i get another housing with the pipe attacheed?
Sounds to me like a weld/braze joint broke.
You need to pull the intake to get to the flange, but you should be able to braze the pipe back.
I currently have a 951 torn down, and the pipe had some pin-holes wjere the hose fits over the pipe. I used a pre-fluxed brazing rod (Home Depot) and a propane torch. Worked like a charm.
The only real problem I see is finding a new gasket.
