somebody could help me; I have a 924s 2.5 cc M44/07 150 cs engine, and I want to change the pistons of a M44/01 2.5 163 cs, for more compression. The pistons have 1 written on them and the others have 1. Could I change them? Are the measurements compatible? thanks help
I think the number on the piston is the bore tolerance group and your block should also have a number stamped on it (likely a 1). I think you can run the different pistons but they need to be from the same tolerance group. Maybe others may have more info.
Wont shaving the head cause issues with timing, due to the shortening of the belt distance?
Thanks to the tensioner, TB length won't be an issue. Vintage racing (VARAC) allows for the removal of 1/10th of an inch as a normal part of head maintenance. More than that and you've given the stock motor an unfair advantage.
