Radiator mounts loose
I installed new mounts on the bottem of the radiator but for some reason the radiator isn't coming up high enough, am I missing something 🤔 also i got this radiator a few years ago from a dismantler my car is a automatic was thier a hight difference between the pre 85.5 autos? Maybe the lower support is not put in right the actual metel strip but I didn't touch that part 🤔?
I have a 86 NA auto.
https://youtu.be/bHXjJVTWoyw
Noahs944 (07-03-2023)
Radiator
You could try shimming up the lower mounts with large washers below the rubber grommets. Did you use new grommets? Perhaps the old ones have shrunk due to heat and age. I don’t know how much distance you have to “make up” but you may have to go as far as developing a 3D printed part. Just some ideas..
