944 central lock switch
Old 06-25-2023, 04:24 PM
WB1990S2
4th Gear
WB1990S2's Avatar
Default 944 central lock switch
Is the central lock switch located in the console a two way switch? I depress mine and the doors lock and the switch lights up, but it doesn't unlock the doors when it is pressed again. Is it supposed too? Should it operate like the roof switch, push it at the bottom and it locks push it at the top of the switch and it unlocks?
Old 06-25-2023, 04:52 PM
orig944
orig944's Avatar
From the owner's manual:
Central Locking Switch
By pressing the central locking switch (A) in the centre console it is possible with the ignition key in position 2 to lock or unlock both doors electrically. As a check, if the doors are locked, a red indicator lamp in the switch lights up.
If one of the doors has been locked manually, the red indicator lamp lights up. By pressing the switch, the door is unlocked; when pressed again, both doors are locked.
With the ignition key removed, locking is possible by means of the central locking switch. To unlock, the ignition must be switched on or the locking button raised.
Old 06-25-2023, 06:56 PM
WB1990S2
4th Gear
WB1990S2's Avatar
Thanks for the information. Went out and tried it. Looks like everything works except the unlock. When its pressed to unlock you can hear the locks start up but not go all the way to the unlock position. Like its not strong enough to push it all the way up. Any ideas on how or what to look at?
Old 06-25-2023, 08:29 PM
orig944
orig944's Avatar
Maybe lubrication of the mechanism. I don't have them, so I've never messed with them.
Old 06-26-2023, 08:01 AM
951Tom
951Tom's Avatar
Do both doors unlock properly when the key is used?
Tom
'87 951
Old 06-26-2023, 06:35 PM
WB1990S2
4th Gear
WB1990S2's Avatar
Yes. Both doors lock and unlock with the key. They also lock with the central switch. They just don't unlock. They move up some when the switch is pressed again but don't unlock.
Old 06-27-2023, 07:37 AM
951Tom
951Tom's Avatar
I'm thinking the electronic solenoids in the door need adjusting. You'll have to take off the door panels to gain access. The procedure is in the factory repair manual.
Tom
'87 951
Old 06-27-2023, 10:36 AM
WB1990S2
4th Gear
WB1990S2's Avatar
I'll see if I can find the manual and give it a try. It happens in both doors. Both move slightly when button is pressed to unlock.
Quick Reply: 944 central lock switch
