Ice Shark light kit
It depends on what kit you want. I got the "Full Boat" Kit.
-Ceibe Lenses and bulbs
-New Main Ground Cable
-Supplimental Ground Cable
-New Main Power Cable (fused)
-Supplimental (fuse box) Cable
-Charging (alternator) Cable
-Headlight Harness w/relays
-Various installation hardware
You can order various portions of the kit, but if you want to do it right, get all of it. This is NOT a headlight swap, it is a replacement for your aged and sub par power and ground harnesses.
http://gururacing.net/LightUpgrade.html
Perry's pics are of the "FullBoat" Headlight package as well as the full battery cable package all in one shot. Ribs, Tim Strayer and others have posted pictures of just the headlight package on Rennlist before. Maybe one of the recent guys can do it again as I don't have a digital camera, yet.
For the time being, like many, many, many months the full battery cable package will not be available to anyone as the last one is going off to Canada this week. The reason being is I need too much volume to buy the fuses and get the factory to make a special run of the fireproof fiberglass sleeve in a size I don't use for anything else that I don't want to tie that much money up in inventory. I will still be selling the upgraded replacement negative grounds off the battery at $44.
As far as the FullBoat headlight kit, the wiring harness is out of stock for the moment. I'll be making some more of them within the month, not sure how many though. So if you want in on that better let me know so I build enough and send in a $100 deposit to secure your spot in the build run.
The total cost of everything in the full headlight package, which is what Matt just posted the other day in his before and after lighting pictures, is $374.50 in the lower 48 USA. That includes a pair of E-Code Cibies @ $105, (4) 90/100 H4 bulbs @ $48 total (an extra set included), the plug and play wiring harness @ $185, adjustable voltage regulator w/h attached brushes @ $16.50 and $20 for the shipping and packaging material.
You can order the items seperate or change the bulbs if you want. For example one guy is moving his car back from the UK and just wants good lenses for right hand lane driving and some high performance 55/60 watt H4s. So that is what he is getting, no problem.
