I'm rebuilding power-steering rack on 924S and noticed a threaded hole with some sort of plastic fitting in it. The plastic seems to have been split and perhaps there is something missing? It's not connected to the oil side and it's not the hole for plastic hose running between bellows, although it's right next to it. Can I put a filter in there?
that hole is for a special tool (a modified bolt) to lock the steering rack in the centered position so you can do an alignment.
the rack gear inside the housing has a dimple in the bottom of it - the special bolt tool has a pointy cone end to engage the dimple.
I'd think you'd want it capped/plugged to keep any grit out. On the manual racks, we usually put a grease fitting in there to ease lubrication of the rack...
