944 Coolant Bleed?
944 Coolant Bleed?
To lay back story my car never got hot until I swapped DME temperature sensors in and out. The car would cool as soon as I turned the fans on, but now it doesn't cool as well. I assume there's a bubble in the coolant system, am I just struggling to get it out? I noticed it got hot when I went to coffee and cars, bled it a day later and it stayed a little cooler the day after I bled it. Any tips on bleeding the system?
How I bled the system: I would open the reservoir fill it up all the way, crack the bleeder, fill the reservoir again then close the bleeder. I would then start the car and open the bleeder and it would spurt a little and then turn into a nicer non-aerated stream as far as I could tell. I would close the bleeder then cap the reservoir and turn the car off. Not sure If I'm missing something or not.
TL;DR: This advice was great and works.
