FS: Porsche Clubsport Steering Wheel
I've got this wheel, and I love it. Two warnings, tho... the 4 plastic tabs that hold the center pad on are very easy to break, .... I'd love to know the proper technique to remove and install without breaking some tabs like I did.
Fear not, the replacement plastic ring with the clips on it is available and not too expensive. I bought two as I saw how easy the first one broke.
The second warning is that if you have an airbag car, installing this wheel will cause an airbag fault.
Rumor says the proper 3ohm (?) resistor in line with the airbag trigger wire will solve this.
I have some spare resistors if you want some, they sell them on amazon in packs of 100s.
I put the resistor in but have not successfully done the reset procedure yet.
Also, the horn contact ring might take some extra parts depending on what you start with. like this-https://944online.com/horn-contact.html
Your experiences may vary..
SeaCay (02-04-2023)
