If you're running a squared setup, what width did you go with and how do you like it?
Hey, Ive also seen Tims video and i'm considering running the same set up on my 89 2.7 NA. Im currently running a set of late offset turbo dials so Id just need to source the early rears. I do not have a TB delete (yet) Do you know if the early 8 rears would fit directly on with my stock setup & camber? and did you have to roll your fenders? Thanks
You would be better off running late offset 8" fronts and late offset 8" rears to get a square setup that way. This is the setup in Tim's video (944 RS build). I would go that route if you want to retain close to factory camber settings.
Source: running early offset phone dials on my S2 and with substantial negative camber (my car is mostly for track/autox so this is ok for my use case)
