A question that I should already know
It's sandwiched between the connecting rod and the crankshaft. The connecting rod attaches the rotating crank to the reciprocating piston. It is a two-piece design and sits in a specific orientation. If it jumps out of this orientation, usually due to excess friction, the bearing is said to be spun... spun out of it's static cradled position.
Ok, so there isn't actually a physical bearing (like a ball bearing or a friction bearing or something) in there, the word refers more to the position of the rod and how it's connected to the crankshaft, is that correct?
